Turn signal fender wire clip
Has anyone else experienced a clip that holds the wiring for the turn signal come loose? This is on the right fender. I was riding and sounds like rubbing against the tire , and noticed the wire clip is hanging loose. Any thoughts or shared experience with this?
- Has thanked: 0
- Been thanked: 4 times
Re: Turn signal fender wire clip
Yes, Mine was doing same thing. Burnt thru wire, repaired and put clip back on tiny post but might have to drill small hole and safety tie it in the future if it comes off again.
- Attachments
- Bare Wire.jpg (42.52 KiB) Viewed 8403 times
- IMG_0599 a.jpg (31.95 KiB) Viewed 8403 times
- Has thanked: 0
Came off again, I removed both factory clips then drilled small hole in tab on inside of both fenders reattached with safety ties. PROBLEM SOLVED!
- Has thanked: 0
Here's a picture of the clips that will not hold. I suggest replacing them with safety ties before your tire burns threw your wiring harness.
- Has thanked: 0
