installed the sway bar - perfect !!!
Posted: Thu Mar 21, 2019 10:56 am
by chris56
look how quiet the front is now - also on higher speed 80mls/h ..
Re: installed the sway bar - perfect !!!
Posted: Thu Mar 21, 2019 6:00 pm
by Zoot
How much work was it to install the sway bar - how much disassembly did it involve?
Is the ride rougher over bad pavement?
Also, tell us about that windscreen, it does not appear to be the OEM screen nor the CalSci piece...
Thanks
Posted: Mon Apr 22, 2019 11:02 am
by rilawrence
Did you install aluminum sway bar end links? Here's the link: https://www.slingmods.com/canam-ryker-b ... ?vehicle=4.
Should the sway bar and sway bar end links be installed together to get the most benefit?
Posted: Tue Apr 23, 2019 6:46 am
by mikey
I think if I were going to upgrade the sway bar, I'd upgrade the plastic bits for those things too.
Posted: Thu Jun 13, 2019 6:35 pm
by AZRIDER
Got the Wife's installed today. WOW what a chore!! Didn't help it was about 90 degrees in the garage. The directions are vague at best, I didn't remove the side skirts and I didn't remove the left lower suspension arm. It is a great improvement at highway speed 80 mph no problem!! Still seams a little twitchy at high speed though??
Posted: Fri Jun 14, 2019 2:11 pm
by Chris2087
Twitchy feeling in steering is more than likely a toe in setting.
Posted: Fri Jun 14, 2019 5:47 pm
by AZRIDER
Gonna check that out next,I need to get a shop manual though.
Posted: Sun Jun 23, 2019 10:51 am
Any advice or direction on the Can Am Sway bar installation? Picked mine up yesterday.
