Hi all . are the rear shocks adjustable on all the ryker models or just on the rally ?.
Re: Rear shock
Posted: Mon Apr 22, 2019 8:41 am
by turbo_tomato
My 600 has an adjustment collar with 5 positions but it was a pain to adjust. I took it to two different dealers and neither could adjust it. I ended up buying a spanner wrench with a socket attachment and a 24 inch breaker bar and it clicked right over.
Re: Rear shock
Posted: Wed Jul 31, 2019 3:39 pm
by Ryley The Ryker
This video will show you how to adjust the spring!
Rear shock
Posted: Tue Sep 03, 2019 1:55 pm
by govaseep
An adjustable toe arm is IMO worth it either way. I dont like the stock one.
Adjusting rear alignment is a little bit of a pain but it just takes some patience.
- Andrew
Re: Rear shock
Posted: Sat Sep 07, 2019 4:19 pm
by Kiwiryker
Thanks so much for the video I have the all in one spanner to do this but it dose not fit in to the gap, and gives you no room to pull up on I was stumped on how to adjust it, but I did not know that you could get one that fitted to a ratchet.
