K&N Upgraded Air Filter for the Can-Am Ryker
Posted: Wed Feb 06, 2019 9:29 am
The “K&N Drop-In Replacement Air Filter for the Can-Am Ryker 600 & 900cc Engines” is an oil based filter that replaces the factory filter to provide superior performance for the Ryker. K&N replacement filters manage air inducted into the Ryker's engine by removing more pollutants than stock filters and encourage the engine's combustion cycle with clean, concentrated air. By removing dust and debris that would otherwise make it into the Ryker's internal systems, the K&N filter provides superior horsepower and torque, and wards against contaminants that would compromise the integrity of the engine. The drop-in filter is easy to install and fits into the factory air box just like stock filters. It is reusable and can be cleaned and re-oiled with the “K&N Squeeze Red Recharger Filter Care Service Kit” that is found on Slingmods.com. K&N filters are a high performance option for superior airflow that can be maintained for long lasting results.
Available now at SlingMods.com https://www.slingmods.com/canam-ryker-r ... filter-knn
