Can-Am Ryker Garage Door Opener
Posted: Fri Feb 08, 2019 4:00 pm
Are you tired of fumbling around for your garage door opener when you get home? Do you find yourself taking your spare opener on those weekend Ryker rides? If you’ve said yes to either of these, then the Mo-door garage door opener for the Ryker is the obvious choice for you! This Mo-Door Garage Door Opener for the Ryker features a stealthy, weatherproof micro push-button switch that allows you discretely place your garage door opener button up and out of site to deter "would be thieves". The opener is compatible with nearly all garage doors openers manufactured after 1995 and includes a 4-Year Replaceable Battery Pack with an 18" wiring harness giving you the flexibility to mount the push-button switch where'd you like. This mod also provides basic, but integral functionality to your Ryker that you’ll enjoy from the moment you install it.
Available now at SlingMods.com https://www.slingmods.com/can-am-ryker- ... er-mo-door
