Can-Am Ryker Front Grille Accent Kit | Carbon Fiber or Colored
Posted: Tue Feb 12, 2019 9:45 pm
Can-Am Ryker Peel & Stick Front Grille Accent Kit
The “Tufskinz Peel & Stick Front Grille Accent Kit” is an easy way to enhance the grill of the Can-Am Ryker. Each piece of the kit is fitted to match a different cross bar of the Ryker's grill, and should be matched to the correct louver before removing the 3M backing strip from the adhesive side of the Tufskinz, in order to ensure proper application. Installation is a straight forward process that involves cleaning the grille, and ensuring that the surface temperature is between 70 and 110 degrees Fahrenheit, before applying the Tufskins to the grille louvers. The colored grill inserts present a dynamic new appearance that accentuate the grill's form, without a need to remove or replace any hardware on the Ryker. The Tufskinz kit comes in carbon fiber, raw carbon, and a sizable variety of colored options to match with the hue of the rest of the vehicle. This embellishment adds both depth and flavor to the front end of the Ryker, and turns the grille from a relatively bland and unremarkable component into an outstanding feature that people will notice.
This item is available at SlingMods.com here: https://www.slingmods.com/canam-ryker-f ... t-tufskinz
