Can-Am Ryker Lower Hood Accent Kit | Carbon Fiber or Colored
Posted: Wed Feb 13, 2019 3:46 pm
by slingmods
Can-Am Ryker Peel & Stick Lower Hood Accent Kit
Break away from the pack with the “Tufskinz Peel & Stick Lower Hood Accent Kit for the Can-Am Ryker”. This aesthetically pleasing mod is installed on the lower portion of the Ryker's hood, where its stylish appearance rejects the status quo with a re-skinned finish that comes in carbon fiber, raw carbon, or any of a wide selection of accommodating colors. The center of this aftermarket peel and stick kit is cut out to wreath the Ryker's hood emblem in a plane of captivating color and design. Application of the kit is easy and requires only that its owner clean the surface area with an alcohol prep pad prior to installation, then ensure that both the kit and the hood are between 70 and 110 degrees Fahrenheit. Once installed the “Tufskinz Peel & Stick Lower Hood Accent Kit “ will stand out as a brilliant new body option that is pleasing to the eye.
This product is available at SlingMods.com here: https://www.slingmods.com/canam-ryker-l ... t-tufskinz
Re: Can-Am Ryker Lower Hood Accent Kit | Carbon Fiber or Colored
Posted: Thu Feb 21, 2019 7:31 pm
by slingmods
