Can-AM Ryker Rear Fender Taillight Accent Kit | Carbon or Colored
Posted: Thu Feb 14, 2019 5:12 am
by slingmods
Can-Am Ryker Peel & Stick Rear Fender TailLight Accent Kit
The Can-Am Ryker is a treasure trove of wide open panels, that beg to be adorned in a layer of stylish Tufskinz. The “Tufskinz Peel & Stick Rear Fender Accent Kit” reworks the tail side of the Ryker in an unmistakable bloom of color, texture, and meticulously cut ridges, that are sure to galvanize the most critical of observers into singing its praises. The kit comes in carbon fiber, raw carbon, and a host of colors that will herald the Ryker as something to be truly admired. Application of the kit is easy and can be done at home. All that is needed in order to install the kit is to make sure the surface it is being applied to is cleaned with an alcohol prep pad, and somewhere between 72 and 110 degrees Fahrenheit. The Tufskinz itself is coated in a transparent layer of UV resistant epoxy resin, to preserve it against the sun as the Ryker races over the open roads. The kit has a circular cut out to show off and accentuate the Ryker's rear emblem, and the whole piece fits marvelously across the tail section of the fender as if it were always meant to be there. Riders will add a whole new look to the Can-Am Ryker with the “Tufskinz Peel & Stick Rear Fender Accent Kit”, and ensure that their ride is the most dazzling thing on three wheels.
This product is available at SlingMods.com here: https://www.slingmods.com/can-am-ryker- ... t-tufskinz
Re: Can-AM Ryker Rear Fender Taillight Accent Kit | Carbon or Colored
Posted: Fri Feb 15, 2019 9:31 am
by Yoder
Does the Orange Madness match the blaze orange panels that can am offers?
Posted: Fri Feb 15, 2019 4:56 pm
by slingmods
Hey Yoder, it's probably not an exact match as these are the color matches from Polaris we've been using for the Slingshot. Would you like me to send you sample of the material to see how close the match is? We'd really like to know that too :)
Thanks!
Posted: Sat Feb 16, 2019 9:17 pm
by Yoder
That’d be awesome. I have access to all the panels so I could confirm all of them if you need help. For my personal ryker though, the orange blaze would be awesome to check out
Posted: Mon Feb 18, 2019 10:23 am
by slingmods
Oh.. awesome. Can you please PM me your name/address. I'll get that going for you my friend.
Posted: Thu Feb 21, 2019 9:58 am
by moniraq
If you decide to buy and apply, would you mind posting a pic? I'm getting the blaze orange on my Ryker and I'd love to see how it looks with the tail accent. Thanks!
Posted: Thu Feb 21, 2019 11:46 pm
by slingmods
Hey Guys, I stopped by the dealership today to snap a pic of our Orange Madness next to the Ryker Orange Blaze! Pretty close match.
Posted: Sat Feb 23, 2019 8:16 pm
by moniraq
Thank you!
Posted: Wed Feb 27, 2019 7:31 pm
by slingmods
