Fuel Door & Upper Fairing Accent Kit
Posted: Fri Apr 26, 2019 9:06 pm
Can-Am Ryker Fuel Door & Upper Fairing Accent Kit by Tufskinz
If you're running our Tufskinz Tank Protector Accent Kit and would like to continue the flow of color up to your Fuel Door and Upper Fairing, this kit is for you! This kit is pre-cut to accent your Ryker Fuel Door and Upper Fairing to add a very custom look to your trike. This kit is available in over a dozen colors including real carbon fiber and is UV coated to protect against fading caused by the Sun's harmful UV rays. Each piece is backed with 3M high strength backing tape for a high strength bond to your factory plastic panels for years of beauty. Please be sure to thoroughly clean the surface area with an alcohol prep pad prior to installation to ensure maximum adhesion. The installation should be done in environment with a temperature between 72 and 110 degrees fahrenheit.
>>>>>>>This product is available at SlingMods.com here: https://www.slingmods.com/canam-ryker-f ... t-tufskinz
