Colored Foam Glove Box Liner (8 Piece Kit)
Posted: Wed May 08, 2019 12:26 pm
Can-Am Ryker Foam Glove Box Liner by Foamskinz
One of the first things we noticed on the ride home from the Ryker dealer was stuff rattling around in our glove box. To address this issue we've partnered up with Foamskinz to bring you a Peel & Stick 8 Piece Glovebox liner kit. This product is made of dual layer EVA foam and backed with high strength backing tape to both insulate your glove box items from engine heat, while providing a rattle free environment. The primary foam color is black with several different accent colors to match your Can-Am Ryker's color profile. Please be sure that you thoroughly prep and clean the surface area prior to adhesion and install the kit with a surface temperature between 72 - 110 degrees fahrenheit.
Foam Glove Box Liner Kit available at SlingMods.com here: https://www.slingmods.com/canam-ryker-f ... -foamskinz
