Can-Am Ryker LED Headlight Conversion
Posted: Wed Jan 02, 2019 11:19 am
Convert your stock Can-Am Ryker yellow halogen headlights to our new bright white LED bulbs. Our LED headlights for the Ryker utilize USA made LED chips and feature an aircraft grade aluminum body design specifically for the Ryker application. Installation is made easy with a special "twist off" base that allows you to use all factory rubber boot covering, with absolutely no modifications, cutting or splicing of any factory wires. This LED kit allows for maximum usable 6000K light output to ensure great visibility during night riding, which also increases rider safety.
Find them here:
LED Headlight Conversion for the Can-Am Ryker
Find them here:
