Can-Am Ryker Foam Grips
Posted: Wed Jan 02, 2019 11:21 am
Can-Am Ryker Foam "Slip On" Hand Grips by TricLED
These Slip On Foam hand grips are a great way to increase rider comfort when cruising your Can-Am Ryker. The larger diameter of the grips reduce wrist-action when twisting the throttle and cut down on road vibration which reduces hand fatigue. No more sore or tingling fingers during and after you ride. To install simply remove your factory Ryker mirrors, apply hand sanitizer to your factory hand grip and push and pull your new foam hand grip into place.
Check them out here:
Foam Hand Grip Covers for the Can-Am Ryker
