Can-Am Ryker / Ryker Rally Quick Release Adjustable Windshield by MadStad | Now available at SlingMods.com here >>> https://www.slingmods.com/canam-ryker-a ... ld-madstad
The MadStad Engineering patented windshield mounting system for the Can-Am Ryker & Ryker Rally allows riders to adjust the height and angle of their Ryker windshield resulting in much smoother airflow, better wind protection and a more comfortable ride than any fixed windshield can provide. Our system for the Ryker is also a quick-release to go on and off the bike in seconds with no tools, so you can ride with the shield or without it anytime you want. Once you try it though, we're pretty sure you aren't going to want to take it off!
Our adjustable brackets clip on and off of four slotted quick-release spools and lock on with two spring-loaded keys. You can adjust the shield for the optimum height, angle and airflow to get the comfort you need for you and your passenger. Our shield goes below the handlebars to give your body more wind protection and we can do this because our brackets let you tilt and lift the shield up and back to get into the front storage box when you need to. There are no compromises, just fantastic comfort and a sporty style that looks like it came from the factory.
The Ryker shields are available in 4 different sizes including 18", 20", 22" & 24" and can be purchased in 4 different tint levels including Clear, Light Gray, Medium Gray & Dark Gray based on your particular preference.
Installation Video Available here:
Can-Am Ryker Quick Release Adjustable Windshields
- slingmods
- Has thanked: 86 times
- Been thanked: 50 times
- Contact:
Our Collection:
Rykers: 2019 Ryker 600 | 2019 Ryker 900 Rally
Spyders: 2017 F3-S | 2018 RT Limited | 2019 F3 Limited | 2020 RT
Slingshots: 2015 Base | 2015 SL | 2016.5 SLE | 2018 SLR | 2020 R
