Front Fender Split Dual Color Running Light Strips - 10% OFF
Posted: Tue Oct 29, 2019 10:32 am
Can-Am Ryker & Ryker Rally Front Fender LED Running Light Strips Available at SlingMods.com: Ryker Front Fender LED Strips
We're happy to introduce our TricFenderz LED front fender running light strips for the Can-Am Ryker & Ryker Rally. These LED strips feature a "split" two color layout that have been designed specifically to enhance visibility of your Ryker, so that you're more clearly seen when out on the open road. The front of the lighting strips features a row of white LED's, while the rear of the strip features a row of red LED's. We've also encased the LED strips in a patented smoked flexible tubing so that the strips blend with the black satin panels of the Ryker when the lighting strips are "off". The installation is mostly Plug N' Play and utilizes an OE style connector to integrate with the accessory power port already on board.
