Ryker Brake Light Flasher | Plug N' Play
Posted: Wed Jan 01, 2020 12:37 pm
Plug N" Play Brake Light Flasher for the Can-Am Ryker available now at SlingMods.com here: https://www.slingmods.com/canam-ryker-b ... -modulator
Make sure distracted motorists are on notice when you press your Can-Am Ryker brake pedal with our Plug N Play Brake Light Flasher. This kit comes with a modulator for each rear brake light that simply plugs inline for a quick and easy installation. Once installed, your brake lights will flash a few times each time the brake pedal is pressed to gain the attention of the vehicles following behind you, letting them know that you're braking. This is a great safety mod and recommended for all Ryker owners.
