Ryker Throttle Response Controller
Posted: Wed Apr 22, 2020 1:15 pm
by slingmods
Available Now at SlingMods.com here: https://www.slingmods.com/canam-ryker-p ... controller
Can-Am Ryker Throttle Response Controller by Pedal Commander
The Pedal Commander for the Can-Am Ryker is a throttle response controller that takes the fun of riding your Ryker to an exponentially funner level by giving you push button control over how fast you want the throttle to respond to power. It brings the Ryker alive and makes it an absolute beast out of corners with instantaneous throttle response when you want it most.
So what does it do exactly?
Since the Ryker is a "drive by wire" system, the signal from the throttle to the ECU is electronic, the Pedal Commander simply intercepts that signal with a 100% plug n play harness and let's you adjust how sensitive you want your throttle to be with the push of a button. Normally while riding your Ryker at speed, you'd have to twist your throttle "all the way back" to get the full power of the engine... you can now compress that throttle map into the smallest amount of wrist action or anything in between, letting you fine tune your throttle to deliver power when you want it and where you want it!
Re: Ryker Throttle Response Controller - $50 OFF Forum Coupon | Exp: 5/19/20
Posted: Thu May 14, 2020 3:05 am
Not waterproof ??? FAIL !
Posted: Tue May 19, 2020 12:22 pm
by slingmods
It's not for everyone Decon.. but it's our #1 selling product this month.. so i must respectfully disagree. The unit supports bluetooth phone support and can be tucked away if you plan on riding in wet conditions. We're also actively working on a silicone cover that can be used with the Pedal Commanders we offer for the Ryker, Slingshot and upcoming Spyder Models. Thank you for your constructive criticism though.. it's always greatly appreciated!
Posted: Tue May 19, 2020 12:28 pm
Tucked away ?
Posted: Tue May 19, 2020 12:41 pm
by slingmods
Tucked away ?
Yes, if you plan on riding in dry conditions... it's probably best to have the Pedal Commander mounted near your throttle so you can adjust it on the fly to accommodate your particular riding mood. If however, you plan on riding in wet conditions you can hide the primary unit in your glovebox or tucked underneath the left upper fairing and control all of the throttle features with your smart phone, as indicated in the video above, with the use of the free app. We do understand that even with the bluetooth control, that some would prefer a waterproof case on the physical unit... so we took the initiative to start creating a silicone cover, since it wasn't something the MFG offered.
