Rally radiator stone guard?
General discussion area on the Can-Am Ryker
User avatar
Zoot
Has thanked: 45 times
Been thanked: 7 times
#1 Post by Zoot » Sun Mar 03, 2019 6:32 pm
Hello All,
I've been checking out the OEM parts manuals to see if the radiator stone guard used on the Rally could be fitted to the standard Ryker.
It appears that the Rally has a different fascia, but the screen attaches with clips so it might be workable.
Has anyone tried mounting the screen on a standard Ryker front end?
JohnWJ
Freezefm
Has thanked: 2 times
Been thanked: 17 times
Re: Rally radiator stone guard?
#2 Post by Freezefm » Tue Mar 05, 2019 4:52 pm
Yes, I have the 600 and purchased the the Protective Steel Grill from the Rally. It fits perfectly.
Francis
mikeyZootJohnWJ
Ryker 600, 2-up spring, Passenger seat/folding backrest, Haze Blue
rilawrence
Has thanked: 13 times
Been thanked: 8 times
#3 Post by rilawrence » Mon Apr 29, 2019 8:35 am
Reposting Francis's reply here for convenience.
https://www.cheapcycleparts.com/oempart ... upper-body
Parts 7600i and 7600j
rakerrykerrider
Been thanked: 10 times
#4 Post by rakerrykerrider » Tue May 14, 2019 9:59 am
Can you give us any hints on installation? Did you have to remove the rocker panels before removing the front fascia? Did you use the clips or something else? I assume it fits directly behind the grill bars. I would also like to put a bug screen in there somehow, did you?
Thanks!
User avatar
iGene_Jr
Been thanked: 0
#5 Post by iGene_Jr » Fri May 17, 2019 4:11 am
Francis
I would love to know how this is installed! Please? :D
Freezefm
#6 Post by Freezefm » Sat May 18, 2019 6:07 pm
2 screws hold the front fascia, located under the radiator.
Then the front fascia comes off by prying on the sides.
The grill is held on to these tabs by the 6 flat clips.
Freezefm
#7 Post by Freezefm » Sat May 18, 2019 6:08 pm
It looks real good on the byke! Took all of 10 minutes to accomplish.
Francis
rilawrence
Mcdvball
Been thanked: 2 times
#8 Post by Mcdvball » Mon Aug 05, 2019 1:04 pm
Francis
I saw your post here to remove the front fascia. Is it just two bolts holding it on underneath? Can you give me an idea where to pry it off. I have to do some surgery to the Ryker myself.
Freezefm
#9 Post by Freezefm » Thu Aug 08, 2019 8:35 am
Francis
Yes, just 2 screws underneath. Pry from the top corners.
Francis
Freezefm
#10 Post by Freezefm » Thu Aug 08, 2019 8:38 am
Pry at these locations...
Francis
