Gas fill cover
- Has thanked: 21 times
- Been thanked: 26 times
Gas fill cover
I live on a gravel and sand road , and anyone that does knows it gets everywhere. Sooner or later it will be in the tank.
I cut a piece out of an old thin mouse pad I had laying around, about 3x4 or so . I put a strip of two sided tape across the top, seals it right off. It just rolls up to put gas in.
Be safe and have fun
vmax3740
vmax3740
- mikey
- Aufgeblssen47
- Has thanked: 0
- Been thanked: 27 times
Re: Gas fill cover
This is the way of the future apparently. Our new RV with Ford Transit chassis has a very similar thing; just a plastic flap that swings out to access the capless filler tube.
BTW: What does the wing nut attach to?
- slingmods
- Has thanked: 86 times
- Been thanked: 50 times
- Contact:
Re: Gas fill cover
We completely agree... especially on the Rally model. Although the "capless" system is convenient for re-fueling it allows dirt and dust to build up in your fill zone. You don't want that stuff in your tank. We''ll have an aluminum "dust cap" here shortly, that features a center vent. I've attached an image for your perusal. It will of course be finished off with a black anodized finish to look pretty. We'll be doing a giveaway on the forum for a few free caps when they come out!
- Attachments
- MVIMG_20190424_131650.jpg (197.1 KiB) Viewed 9062 times
Our Collection:
Rykers: 2019 Ryker 600 | 2019 Ryker 900 Rally
Spyders: 2017 F3-S | 2018 RT Limited | 2019 F3 Limited | 2020 RT
Slingshots: 2015 Base | 2015 SL | 2016.5 SLE | 2018 SLR | 2020 R
- slingmods
- Contact:
Re: Gas fill cover
Sure.. we can look into that!
Our Collection:
- Aufgeblssen47
- Has thanked: 0
- Has thanked: 13 times
- Been thanked: 8 times
- Aufgeblssen47
- Has thanked: 0
Re: Gas fill cover
Update!!! My plastic cap failed. Apparently the wind seen in that area is enough to lift it out of place. I only went 50 MPH max. on a short trip, and it had been blown away. NOW I have a chromed metal cap (also from my kegerator), that fits great! I added a little handle in the middle made out of foam double stick tape that works well. I doubt wind will be able to lift metal!Aufgeblssen47 wrote: ↑Sun Apr 28, 2019 4:44 pmI found a cover from a beer keg top fits perfectly! I have a beer kegerator.
