first Service Ryker 600
Posted: Mon Apr 29, 2019 2:25 am
by Charles
when should I service my Ryker 600 (first Service from new ) ....
Dealer indicated its not require until the 1st year is up or 10000 km , which ever comes first that from new
I have 1500KM should I go and get the oils checked ?
Re: first Service Ryker 600
Posted: Mon Apr 29, 2019 5:30 am
At 6,000 miles. You can check your oil level yourself in the meantime - no need to bring it to the dealer!
Personally, I'm not changing my oil until 6,000 miles, even if it takes 2 years to get there. TIME does not deteriorate oil, only MILES do! (actually number of engine revs to be exact)
Posted: Tue Apr 30, 2019 2:24 am
by Charles
thanks for your reply
Posted: Wed May 01, 2019 1:33 pm
by 904 Rally F1 Team
Aufgeblssen47 wrote: ↑Mon Apr 29, 2019 5:30 am
I totally agree. GO ICEMEN!
Posted: Mon May 06, 2019 8:10 pm
by Zoot
I don't agree. Condensation can develop in engines which aren't operated long enough to get up to temperature and cook off the moisture. Unburned fuel can get into the engine, combustion products, etc. etc. "Worn out" oil is not the only reason to change,there is also contamination.1,000 miles of 1-mile trips are probably more damaging than a 1,000-mile weekend.
When a manufacturer's service schedule calls for xxx miles OR yy months, there is a reason.
Posted: Tue May 07, 2019 4:46 am
Zoot wrote: ↑Mon May 06, 2019 8:10 pm
But do
YOU takes such short trips??? One must use one's own judgement, and act according to their particular unique situation. The manufacture's recommendation is based on WORST CASE SCENARIO, one which very infrequently will happen.
Besides, I can't imagine that ANY Ryker owner has theirs as strictly a commuter, going only to work 5 days a week, going 1/2 mile each way and coming home! (& never going for a
RIDE!)
Even if somebody DID commute 1/2 mile round trips, and went for a nice
RIDE on the weekend, it would NEGATE (i.e. remove/burn off) any moisture build-up!
Posted: Wed May 08, 2019 5:57 am
by Freezefm
Charles wrote: ↑Mon Apr 29, 2019 2:25 am
From the online manual...
FIRST INSPECTION
We recommend that after the first 5 000km (3,000mi) of operation, your vehicle be inspected by an authorized Can-Am On-Road dealer, repair shop, or person of your own choosing. The first maintenance is very important and must not be neglected. NOTE: The first inspection is at the expense of the vehicle owner. Werecommendthatthisinspectionbe signedby theauthorizedCan-AmOn-Road dealer, repair shop, or person of your own choosing having performed the first inspection.
Francis
Posted: Wed May 08, 2019 7:23 pm
by Zoot
Aufgeblssen47 wrote: ↑Tue May 07, 2019 4:46 am
But do
RIDE!)
So, with lots of caps and exclamation points and boldface, you are saying I am wrong because people ride more than the worst-case statemenet. My point, simply, is that elapsed time between oil changes
does matter, not simply total miles covered. It's the same for brake fluid and coolant.
Posted: Thu May 09, 2019 5:15 am
Zoot wrote: ↑Wed May 08, 2019 7:23 pm
But do
RIDE!)
If you used "can" instead of "does" matter, you would have been dead nuts accurate. Since you didn't, not so much.
Do you do everything in your life assuming absolute worst case scenario? I don't - I live my life rather worry about can very unlikely happen, rather than live like Howard Hughes.
I never change my brake fluid. If I start having a brake problem (i.e. mushy brake pedal), I change it. If it ain't broke, I don't fix it!
I also very occasionally test coolant with a gauge. Don't capriciously change it.
