This Tucker Would Work Fine For Ryker Front Replacement
Posted: Mon May 06, 2019 9:16 am
by Aufgeblssen47
Yes, here's one in the USA for $70 including shipping:
https://simpletire.com/kumho-t125-80d16 ... GrEALw_wcB
Re: This Tucker Would Work Fine For Ryker Front Replacement
Posted: Tue May 07, 2019 11:52 am
by Aufgeblssen47
This tire has a speed rating of "M", which is 81 MPH. The Ryker 600 is rated at top speed of 82 MPH. I NEVER will ride that fast with my 600, so it will be fine!
But also keep in mind, that tire is rated at 1,600+ pounds. Weight of the Ryker is much, much lower than that,
Posted: Wed May 08, 2019 8:49 am
What's a Tucker?
Posted: Wed May 08, 2019 9:35 am
by Aufgeblssen47
KC61 wrote: ↑Wed May 08, 2019 8:49 am
What's a Tucker?
Synonym for tyre or tire.
Haven't you ever been "all tuckered out"?
Posted: Fri May 10, 2019 11:51 am
by Aufgeblssen47
The tire has an "M" speed rating, which is good up to 81 MPH. But that is based upon 1,600 pounds on the tyre. If a 300 pound ryder is on Ryker, that is less than 300 pounds on tyre. So it should be just fin & dandy for a Ryker front tyre!
Posted: Mon May 13, 2019 11:30 am
by Aufgeblssen47
Apparently, when you compare a 145/R60-16 tyre with a 125/R80-16 one to each other, the "temporary spare" tire (the 125) is a full inch LARGER in outside diameter. The current (145) tyre seems pretty close to the fender as it is, but I think there is STILL enough space to be able to use it.
Posted: Mon May 13, 2019 11:53 am
Looks like a Mother Tucker
Posted: Mon May 13, 2019 1:40 pm
by Aufgeblssen47
KC61 wrote: ↑Mon May 13, 2019 11:53 am
Like they say "truth is stranger than fiction"!
