Page 1 of 3
Wheel nut
Posted: Sat May 11, 2019 9:47 pm
by Macsmax
Wheel nut was mentioned one other place here, but no big response. SAE 2 1/2 is the same as 65mm and cheaper. You can get them at Northern Tool. 22 dollars.
Re: Wheel nut
Posted: Sun May 12, 2019 3:08 am
by otis30673
I was just riding along may 8th and herd a bad sound from the rear stop to check it out and my rear tire wheel nut was starting to come off, have any body had this happen .
Re: Wheel nut
Posted: Sun May 12, 2019 6:57 am
Huh??? How do SAE threads fit on a metric shaft??? I be totally confused.
Re: Wheel nut
Posted: Sun May 12, 2019 7:33 am
He's talking about the wheel nut socket not threads. 65 mm = 2.55 inches so what he is saying is a 2 1/2 socket might work for the wheel nut.
Re: Wheel nut
Posted: Sun May 12, 2019 7:38 am
by Macsmax
Fit is excellent. Already tried it.
Re: Wheel nut
Posted: Sun May 12, 2019 7:43 am
Seems like the only time one would take off a wheel, is having a new tire put on, and the tire shop will handle removing wheel. Even if you order a tire online, IMHO.
Re: Wheel nut
Posted: Sun May 12, 2019 7:51 am
Did you remove the nut and re torque to try it? Great find by the way.
Re: Wheel nut
Posted: Sun May 12, 2019 7:52 am
Most if not all tire shops will not have this socket available. One should carry this with them.
Re: Wheel nut
Posted: Sun May 12, 2019 8:08 am
OK, thanks.
Re: Wheel nut
Posted: Sun May 12, 2019 9:26 am
Went to their website; they have 2 3/8" and 2 5/8", no 2 1/2". Got part #?
https://www.northerntool.com/shop/tools ... _200639333
