OIL CHECK ????
Posted: Mon Jun 10, 2019 6:27 pm
by 4u2nv
What's your way of checking the engine oil , my dealer states that BRP is sending out a new way to do it !!!!
Re: OIL CHECK ????
Posted: Tue Jun 11, 2019 6:31 am
The Manual says to warm up the engine, then shut off, wait 30 seconds & pull dip stick out, wipe off, then fully screw in & remove to check. Makes a huge difference in reading, vs. checking it cold after sitting overnight.
Re: OIL CHECK ????
Posted: Tue Jun 11, 2019 9:23 am
Yep, the bike has to be warm and checked within 30 seconds or so of turning it off. If you check it cold it will register below the minimum mark.
Re: OIL CHECK ????
Posted: Tue Jun 11, 2019 11:15 am
One must take what the dealer says with a grain of salt; my dealer said 1st oil change is at 3,800 miles, when in fact it is clearly 6,000 miles, according to Manual.
