Does Ryker Fit w/o Major Difficulties Onto A 5 Foot Wide Utility Trailer???
Posted: Mon Jun 17, 2019 11:16 am
I mean, it is 59.4" wide, so there is only 0.3" to spare on each side whilst loading onto trailer.
Re: Does Ryker Fit w/o Major Difficulties Onto A 5 Foot Wide Utility Trailer???
Posted: Mon Jun 17, 2019 3:25 pm
Sounds pretty tight to me !
Posted: Tue Jun 18, 2019 7:45 am
Decon Blue wrote: ↑Mon Jun 17, 2019 3:25 pm
It would be! Looks like the minimum trailer size would be 6 X 10.
Instead of towing on a trailer, I've just sent a message to Can-Am asking if the Ryker be towed safely (i.e. w/o transmission damage) on a dolly with the rear wheel on the ground. Will be interesting what they say.
Will be a helluva lot less weight towing & much better resulting MPG.
Posted: Tue Jun 18, 2019 8:16 am
Tow it ?? RIDE IT !!
Posted: Tue Jun 18, 2019 8:18 am
Decon Blue wrote: ↑Tue Jun 18, 2019 8:16 am
Only in a perfect world.
Posted: Thu Jan 09, 2020 5:46 pm
by bbells
Back it into the trailer and you will not have a problem. If too close, get off and pull the front wheels over. You will be happy with the fit. If nervous or you trailer alot, simply cut the rail off behind the trailer fender and reweld on using a 1 or 1.5" square tube. I have a 2x4 screwed into the floor on each side to stop the front wheels from going too far into the trailer. After loading you can put 2x4's on the gate side, too. Much better than having too big of a trailer.
Posted: Fri Jan 24, 2020 7:20 pm
by Miles42
im thinking 6 ft min.
