How Much Oil Have You Had To Add Prior To 6,000 Miles?
Posted: Sat Jul 13, 2019 8:48 am
by Aufgeblssen47
Just curious. I'm at about 800 miles, and it looks like it is about 3/4 of the way to needing to add a quart.
No poll capability here?
Re: How Much Oil Have You Had To Add Prior To 6,000 Miles?
Posted: Tue Jul 16, 2019 8:33 am
by cattleshow
Caution,you probably are not checking the oil the proper way. Please read your manual or you may do a lot of damage.
There are post also on the oil check procedure. You cannot check the oil cold.
Posted: Sun Jul 21, 2019 9:45 am
by Aufgeblssen47
Update!!! I checked the oil today EXACTLY as the Manual specifies, and sure enough the oil is FULL!
My bad for apparently checking it the wrong way before.
